well it all started about 18 months ago, when i brought a set of E36 M3 evo ITB's off ebay, but had a nightmare when it came to trying to fit them, what did'nt help is that i worked everything out using gaskets and not actually matching the ITBs to the head, (becuase i did'nt want to take my inlet manifold all off in case it all went tits up and did'nt work, lol) so i machined my self an aluminium adapter plate to match the S50 itbs with the M42 head, and that went fairly well, but i was never happy with having the adapter plate, one reason among other was that the ITBs and plenum sat quite high in the engine bay and stoped me from using my strut brace,
heres how i was first going to have the itbs
and heres the aluminium adapter plate
time went by and i had the itbs fitted for about 8-months, then just recently i was browsing through ebay for a cylinder head, and found one for ?30, so i brought it with the intention of practicing headwork on it, and making the itbs fit properly,
heres the main problem with the itbs, the ports are the same size, just dont quite match
so i started to grind out the head and itbs so that they matched each other, that was only about an hours work, with a drill and tungsten carbide bit.
now its a case of bolting them to the head when the bolts do not all line up, you can see in this pic that there very very close, and i did even have to file a small ammount from either end so that the itbs sqeeze in around the studs,
so with most of the obsticles out of the way i got on with making some little brackets up, and very luckily i happened to have some 2" aluminium angle thats about 3-4mm thick so i used that for some little right angle brackets.
and thats about it really, then got them bolted to the car
its still abit of a mess and needs some more tiding, but slowly getting there, i am working now on the spare cylinder head, the porting is going very well indeed, i am fitting bigger 34mm inlet valves and the inlet and exhaust valve seat/throats are being machined out to the maximum they can be,
heres some of the head work
before
after
once all this is done then i will start on the bottom end, making it 2 or 2.1 liter, and a silly high RPM
steve
________
Ecig forum
