High pitched noise coming from front area of the car
Author Topic: High pitched noise coming from front area of the car  (Read 2348 times)
Snoe30
« on: December 18, 2019, 02:52:30 PM »
Hello,
I’m reaching out to see if anyone’s had the issue of having a high pitched noise come from the front of the car , it only happens when I’m doing about 65 to 70 in 5th gear rpms at about 3000, I tried to duplicate the sound with the car in 4th gear but i don’t hear the sound. When I press the clutch pedal in the sound goes away and when I let off the accelerator pedal the sound goes away. The car in question is a 1991 bmw 318is I don’t know the age of the clutch or any bearings under the hood I put a new belt on the power steering pump and changed the alternator for an unrelated issue to the sound. I’m going to change the diff fluid this weekend for a scheduled maintenance.
Thank you,
colin86325
Re: High pitched noise coming from front area of the car
« Reply #1 on: December 19, 2019, 04:26:32 PM »
Might want to check your driveshaft center support bearing while you're under there.
Bmerdoctor650
« Reply #2 on: February 11, 2020, 05:39:48 PM »
something tells me that your clutch release bearing (throwout bearing) is starting to go out.
