Author Topic: How to make easy HP M42 E36 ?  (Read 5272 times)
Petre.E36318is
« on: December 26, 2018, 01:03:59 PM »
Hello fellas , I have a question I have a 95' e36 M42B18 ( 140 HP )and i want too do some modification to have around 200Hp .😁
Some suggestions on what I should change to reach that power🤔
Nick_318is
  • -Receive: 11
Re: How to make easy HP M42 E36 ?
« Reply #1 on: December 26, 2018, 02:34:12 PM »
Hi Petre, sorry to be the bearer of bad news but you're not going to get 200hp out of it cheap or easy. The best modifications you can do easily will be a chip and maybe a light weight fly wheel to wake it up a little.
Beyond that the next easiest power gains are probably to turbo or supercharge it. If you want 200hp N/A you're going to have to do a full stroker build.
« Reply #2 on: December 26, 2018, 06:43:19 PM »
It's easy. Just look for a complete Downing Atlanta Supercharger kit (DASC). They're not easy to find, but they will pop up occasionally on eBay.
Otherwise it's a custom turbo, an S42 recipe like Warsteiner's build, or something like the Metric Mechanic Rally M42. None of these are cheap...check with Warsteiner, he might still have some spares.
Petre.E36318is
« Reply #3 on: December 28, 2018, 12:00:30 PM »
Thanx for the tips
If i put a Turbo or a supracharger kit what PSI i expect to be a safe for the Stock internals ?
I heard they come from the factory with forged internals , it's that true ?
Warsteiner
  • -Receive: 21
« Reply #4 on: December 28, 2018, 01:05:34 PM »
I'm a little late to the party but hey..... 8)
If you're interested in a 212HP motor send me a PM. Change the cams and you can probably get another 20HP.
There are lots of trick things to do for power in the M42. Tuning, stroking, porting,etc or add a SC or turbo.
Don't know about safe PSI since mine is naturally aspirated.
Cheers,
~Ralph
Petre.E36318is
« Reply #5 on: February 18, 2019, 01:49:00 PM »
Question , if I put a Maf from a M44 to my M42 engine its gone too run properly ? or i must change tha ecu to?
