Author Topic: AC Hoses - Updated Barrier Hose p/n's  (Read 4241 times)
jrobie79
« on: June 19, 2018, 11:28:12 AM »
Does anyone have updated part numbers for barrier hoses for the m42 A/C system?
I checked realoem, and used a 1992 318i after March (when they were upgraded to barrier hoses) but the part #'s aren't making sense to me
My compressor does not have threaded fittings on the actual hose ends, this is what the end looks like:
however when I go to pelican parts or look up the late late cabrios, the part number for that hose indicates a threaded end fitting
In regards to custom made lines, I was quoted $325 for the (3) lines that require the barrier hose (the two going to the evaporator already area barrier)...Compressor --> Condenser, Condenser --> Dryer, Compressor --> Evaporator (the line pictured).
Is it possible to swap the top manifold 'plate' on my 10PA17 compressor to accept the threaded fittings and use lines that are more easily found and cost significantly less to have custom made?
colin86325
Re: AC Hoses - Updated Barrier Hose p/n's
« Reply #1 on: June 21, 2018, 11:26:04 AM »
I'd certainly make some inquiries about swapping the top plate out.  The Denso unit appeared in many vehicles, so I wouldn't be surprised if the appropriate plate was available to allow you to swap to a more generic (and cheaper) option.
jrobie79
« Reply #2 on: July 03, 2018, 08:14:58 AM »
bit the bullet and had new hoses made. $200, oh well. I really want to take advantage of the e30 mpg for my daily commute compared to my truck, so it was worth it.
