Author Topic: Humming fuel pump pressure regulator  (Read 1978 times)
sopicki
  • Just Wrench'n
« on: May 13, 2018, 11:16:10 AM »
Hi all,
Thought I'd share something I just learned for those with a similar problem.
My car started to hum a couple of years ago.  I was able to track this down to the fuel system as I could feel a definite vibration from just about any fuel line.  I immediately thought it was the generic AutoZone fuel pump that I had recently bought for it so I quickly sourced an OEM VDO pump with no change whatsoever.  (on a side note, when I removed that AutoZone pump I discovered that it too was a VDO pump!)
Nothing seemed to run badly so fixing the hum was not a real high priority, but by this spring I was starting to get annoyed by it so while ordering parts to track down some other problems I decided to replace the fuel pressure regulator.
Replacing the regulator is pretty easy and I replaced it with a BWD part from O'Reillys.  Totally fixed the humming and I think it idles a little better now too!
Just food for thought for those out there with musical cars!
Regards!
« Last Edit: February 15, 2021, 08:43:17 AM by sopicki »
Bob
Massillon OH
'91 318ic
'64 Land Rover SIIa "Nellie"
