PAPER OR PLASTIC
For Sale
FS: M42 Turbo Stuff: cylinder head, camshafts, pistons, gt2871r, ID1000's
Topic: FS: M42 Turbo Stuff: cylinder head, camshafts, pistons, gt2871r, ID1000's (Read 3804 times)
ccsdo5
Freshly Registered!
February 11, 2018, 02:15:35 PM »
Have a bunch of parts from a previous turbo build, the engine developed crank walk before it even had 100 miles on it. I no longer plan on doing a high horsepower m42 turbo build and have currently been running a stock m42 at 8psi for the past year. Figured I might have an easier time selling these parts here than on R3v. Everything is located in Westchester, NY 10598 willing to ship stuff at buyers expense. PM me with any questions.
- Cylinder head with VAC High performance stainless steel valves (7mm), VAC High performance valve spring kit w/ steel retainers and spring seats, head got new valve seals and a 3 angle valve job. I ran it for a little so I would check it is square before installing. $1000
- VAC turbo ground cam shafts (pretty sure they are actually cat cams 260 / 242 degree) $800
- CP forged Pistons 85mm overbore 8.5:1 compression ratio. Going to leave connecting rods attached You might need new rings I gaped them for my block and yours might be different. Starting the clean the carbon build up off them from running the car rich. $700
- Garret GT2871R Turbo bought off a member from zilvia, has no shaft play, I have a T2 internally gated exhaust housing and a T3 ford style exhaust housing for it will come with both. $800
- COMETIC 0.098" MLS head gasket $200
- ID1000 injectors (need to be cleaned) also come with adapters to ev1 style so they are plug n play $400
ccsdo5
Freshly Registered!
Re: FS: M42 Turbo Stuff: cylinder head, camshafts, pistons, gt2871r, ID1000's
June 17, 2018, 09:52:48 AM »
bump still have this stuff.
PAPER OR PLASTIC
For Sale
