Hello fellow m42 enthousiasts
This forum has been a big help so far but this time i'm stuck and desperate. Maybe there are topics about this problem but I searched for days without exact solution.
I replaced my timing chain and now the car idles very rough and occasionally stalls. If I rev it there is a bang in the intake manifold.
I had a rough idle before so I cleaned the icv. When that did not improve it like I wanted I replaced it.
I'm starting to think I did not replace the timing chain as I should have.
The cams are square at the back. the two arrows facing up and the cam lobes are facing eachother upwards. Piston 1 is at TDC.
BUT I think I locked the flywheel the wrong way. I used the hole covered by a rounded trapezium shaped piece of rubber behind the sump to keep everything in place but it still could wiggle a teeth or two.
I feel like an idiot but can someone post a picture of the correct hole where the flywheel locking pin should be put in. I searched online but the pictures aren't clear enough.
PS: the engine turns and starts. I tough the m42b18 was an interfering design and that the valves would touch the piston if I cranked it manually. This did not happen so I tought the replacement was succesful.
I have some pictures. they're all taken with engine at TDC except for those with the hole I used for locking the flywheel. Can't remember if I put it at TDC1.
I also have pictures of the crankshaft sensor pulley. maybe the gurus will see if it's positioned the right way (it's at TDC).
Can someone help me out? Thanks!
