Author Topic: Low cost turbo, CR question  (Read 3211 times)
Tommy
« on: December 09, 2017, 03:36:51 PM »
Hello everybody, I plan on doing a low cost turbo project. Stock ECU, stock internals, boost only about 0.3-0.5 bar, pull through AFM setup... I have a  question about lowering the compression ratio. This build being low cost, and me being broke student, MLS thick head gasket is not an option. I have the engine fully disassembled so I thought I would put in m40 con rods, but they are too short and it would give me around 6.8:1 CR which is too low. I think my only two options are: 1. Stacking 2 head gaskets - Will they leak? Will this be reliable? 2. Decking the pistons about 1.75mm - Will they be still strong enough for the FI? Both of these options are cheap and will leave me with around 8.5:1 CR which is perfect, but I can't decide which route is better/more reliable. Any thoughts?  :D
1998ccc
  • -Receive: 6
Re: Low cost turbo, CR question
« Reply #1 on: December 09, 2017, 08:16:46 PM »
I had a buddy years ago that built a stroker motor where the pistons he was using came out of the block too much.  He stacked 2 stock headgaskets spraying them with copper spray before install.  They never gave an issue.
Tommy
« Reply #2 on: December 10, 2017, 03:24:54 AM »
Thank you for your answer! I was already leaning more towards the stocking headgaskets idea, because i am not really comfortable with shaving of the pistons for boost applications. :D Can you give me some more answers? - Was your friends stroker m42b18 as well? Did he fully spray both gaskets? Or did he leave the "inside" area where the gaskets were touching uncoated?
