20psi on M42
Author Topic: 20psi on M42  (Read 5485 times)
Gunni
20psi on M42
« on: January 29, 2007, 04:24:27 AM »
Whats needed engine wise, assume I got everything else covered.
2002maniac
20psi on M42
« Reply #1 on: January 29, 2007, 01:19:12 PM »
custom rods, low CR forged pistons, and a good headgasket should do it.
sheepdog
  • Site Admin
20psi on M42
« Reply #2 on: January 29, 2007, 01:55:34 PM »
I would consider o-ringing the block/head. Less gasket troubles.
Gunni
20psi on M42
« Reply #3 on: January 29, 2007, 01:56:20 PM »
Why diffrent rods aren´t they forged already?
would I be able to run lower compression only?
i.e thicker metal gasket, mill the pistons?
bar73k
20psi on M42
« Reply #4 on: January 30, 2007, 05:53:29 AM »
rods are fine to handle 20 psi
a steel gasket and lower compression pistons are all you need
you could probably get away with a standard headgasket.
its all in the tune, if you can tune the car well you dont need to go over the top
nuvolarossa
20psi on M42
« Reply #5 on: January 30, 2007, 06:23:30 AM »
I'm impressed of the power that M42 can put out with near stock internals!
not to hijack thread, but only for comparison:
What's need for make a M44 "20psi capable"? The rods are forged as m42, but crank is cast... it's important that the crank is forged with FI? How much psi M44's crank is capable?
thank you and sorry for hijack.
Gunni
20psi on M42
« Reply #6 on: January 30, 2007, 06:28:25 AM »
I wouldn´t think the cast crank be a issue as it is by far the strongest part of the engine
nuvolarossa
20psi on M42
« Reply #7 on: January 30, 2007, 08:11:23 AM »
Quote from: Gunni;18444
so, why all say that M44 can't handle boost, that M42 is better because it has forged parts... the only part that M42 have forged more than M44 is crankshaft:confused:
Gunni
20psi on M42
« Reply #8 on: January 30, 2007, 09:00:17 AM »
I´m sure it´s engine management issue,
as was with the M20 until people started taking control over the ignition
10psi used to be the max on a motronic system wich has been proven wrong numerously
nuvolarossa
20psi on M42
« Reply #9 on: January 30, 2007, 10:56:47 AM »
but with a standalone/piggyback and a perfect air fuel ratio, low CR forged pistons and eventually turbo rods it can handle 20psi as a M42, correct?
Gunni
20psi on M42
« Reply #10 on: January 30, 2007, 11:17:17 AM »
it´s possible that by using only lower compression trough a thicker gasket and right timing and afr´s you should be able to run it,
kowalski
  • El\' Duder
20psi on M42
« Reply #11 on: January 30, 2007, 12:34:04 PM »
so a if someone were to build a stroker with an m44 crank they'd be fine to run >25psi?
Sale:
Fore Sale Thread
nickmpower
20psi on M42
« Reply #12 on: January 30, 2007, 03:10:39 PM »
well i dont think anyones ever been ummmm brave enough to try
zerofreez
20psi on M42
« Reply #13 on: January 30, 2007, 05:15:44 PM »
You could get away with thick MLS headgasket technically.  If you get the CR around 8.5 or 9.0 to 1 you shouldnt have a problem.
I used to be into the turbo mitsubishi's and they had no problem running 20psi on cast rods and crank as long as you fed it good gas and your tune was good.
2002maniac
20psi on M42
« Reply #14 on: January 30, 2007, 07:07:03 PM »
Quote from: nuvolarossa;18453
I have not heard anyone say that.  There is even a bolt on supercharger kit that alot of M44 guys use (DA)
