Backfiring and hesitant throttle
Author Topic: Backfiring and hesitant throttle  (Read 3764 times)
Johnnypjr
« on: September 02, 2017, 09:32:16 PM »
Hey everyone. Super new to this so I hope I'm in the right place. I have an e30 318is and I keep having a backfiring/hesitation when under heavy acceleration. I replace the cps, checked for all vacuums leaks, cleaned the air flow meter. I replaced with a known working iac, kinda stumped atm. I don't know if I should start look towards fuel pump. Fuel pressure regulator  seems good. I'm just out of ideas.
Re: Backfiring and hesitant throttle
« Reply #1 on: September 07, 2017, 01:53:31 AM »
How do the spark plugs look? How about the spark plug wires?
othatseric
« Reply #2 on: September 11, 2017, 10:20:58 AM »
Have you tried replacing the fuel filter?
"Overkill is underrated my friend"
-Col. Hannibal Smith
colin86325
« Reply #3 on: September 12, 2017, 10:34:25 AM »
Backfiring points to unburnt fuel. I'd suspect the ignition system, possibly the coils.  Test them with an ohm meter.
Johnnypjr
« Reply #4 on: October 26, 2017, 06:57:11 PM »
I ended up replacing all coils, didn’t fix the problem. Then while looking down after replacing all of that. Turns out one of the wire had a rub mark on it and I guess it was ground out. I fixed that and started running great! Thanks for all the input!
colin86325
« Reply #5 on: October 27, 2017, 12:26:47 PM »
Awesome, glad you got it sorted!
