Author Topic: M42 DASC limits  (Read 3712 times)
Jpkallday
  • DASC E30 318IS
M42 DASC limits
« on: August 15, 2017, 06:39:49 PM »
Hi all, I didn't see anything in the forum about a 1991 318is DASC, feel free to redirect me if I missed something. So I have a DASC kit on my car, and I'm currently only pushing 5PSI and without a tune. I'd like to be at at least 8-10 PSI, and hopefully get a custom chip from Mark D'Sylva like I had in my first 318is. How much boost can I safely push? I know the PO had the fuel system upgraded, it looks like 90-100ish psi under boost on the gauge. I do not have any added cooling but plan to do so before more boost. I'd like to at least hear the S/C a little bit as well as it is inaudible right now. Any tips or suggestions? Thanks.
91 318IS DASC
johna
    • My BMW 3 Series Website
Re: M42 DASC limits
« Reply #1 on: August 16, 2017, 04:04:31 AM »
I can't help with most of your questions but maybe on the noise question.
What air filter are you running? My car had the original K&N filter that comes with the DASC kit when I bought it and i could hear the super charger. I have since replaced with a sealed air filter and now can't hear it any more.
Jpkallday
  • DASC E30 318IS
Re: M42 DASC limits
« Reply #2 on: August 16, 2017, 10:21:36 PM »
I'm honestly not quite sure. It looks awfully small and its a grey color. I may try a different filter, I was pretty happy with the KAmotors intake on my first car. Thanks for the input.
91 318IS DASC
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: M42 DASC limits
« Reply #3 on: August 20, 2017, 08:11:03 PM »
It depends on how the tuning is done. With the FMU/RRFPR you are more limited as you dont have precise control over the injectors. If Mark D tunes the car for larger injectors you should be able to get a better idea of the power capability of the fuel system.
Your main limitation is maximum torque with the factory rods. The stock DASC kit still leaves a lot of room to grow. I think the main limitation will be how small of a pulley diameter you can run before the Eaton is out of the efficiency range and IATs start climbing.
-Nick
91 E30 M42 with VEMS
