Author Topic: Going to check out a 318is Slicktop  (Read 4326 times)
Djnewman001
« on: January 29, 2017, 01:20:00 AM »
Hey guys, I'm going to look at a 318is slicktop and I pretty much have learned what the trouble areas are for rot on the exterior. Is pulling up the carpet up a pretty attainable task? This will be my first e30, I'm coming from VW's. Anything else I should really look out for? Im going to try my best to crawl under to see as much as I can.
Its a northeast car but the guy that has it now says the undercarriage is in great shape, he "says" it wasn't winter driven but it does have the beginnings of the battery box rot. I can see from the pics.
Thanks!
Re: Going to check out a 318is Slicktop
« Reply #1 on: January 30, 2017, 06:41:05 PM »
I made the same jump as you did - came from a Golf I and a Jetta III to these little lovelies. Very similar cars, really. You won't see anything unfamiliar except maybe the engine orientation.
Carpet really isn't that easy - it's deeply molded with thick foam padding attached to it. The only spot I'd really like to see under the carpet that severe rust can hide, is under the carpet is on the firewall and at the bottom of the a-pillars. You should be able to peek under the passenger side carpet without taking anything apart. If I can't get my head in there, I'll just hold a phone out and snap random pics until I get what I'd like to see. Pedals are in the way on the driver's side and you can't pull the speaker & grille because there is another electrical component under there. You can see a bit of the lower a-pillar through the front door openings, but not enough to be 100% sure.
Also look for any signs of rust staining near the lower corners of the windscreen seal. In addition to the commonly-corroded license marker lights, turn signal mounting flanges, battery tray and tool pocket...check the upper pinch welds at the trunk hinges.
Gunnar
  • Seatowndirty30
  • 91 318is brilliantrot slicktop, 545,000 miles og.
« Reply #2 on: February 09, 2017, 03:45:36 AM »
Rust on 318is' isn't a thing, BMW built them with extra special care 😉. Kidding, but my stock iS has 540k miles and no rust at all.
91' 318is Brilliantrot slicktop, 545,000 og miles.
