Author Topic: no clutch pedal pressure after engine and clutch swap??  (Read 2382 times)
steel330i
  • Half the cylinders, half the problems?
« on: January 11, 2017, 01:24:49 PM »
So did an m42 swap into my 91 318i, new clutch while.we were at it and then when we started it up and attempted to drive it up the street, I had no clutch pressure and was burning clutch along with some very metallic sounds from under the car...any ideas on what to look for?
In pursuit of perfection...just not in a Lexus
Re: no clutch pedal pressure after engine and clutch swap??
« Reply #1 on: January 11, 2017, 07:07:54 PM »
I'd pull the slave cyl to see what's going on.
Did you swap the slave cyl? If so, try a reverse bleed. Here's a demo from BMP:
https://www.youtube.com/watch?v=wdf--suwqw0
Did you ever have any pressure in the slave cyl? It's also possible that the shift fork fell off the pivot & let the slave cyl blow the rod & piston out. Those pivots can break too. Also, the fork retaining clip could have slipped out. Could even be a bad release bearing or the wrong part number. There are several different thickness release bearings, it's possible you got the wrong kit.
steel330i
« Reply #2 on: January 12, 2017, 05:12:55 AM »
Dave,
Thanks for the reply, I need to check all of these, it feels in my guy more mechanical than hydraulic. However, I hope like hell its as simple as replacing the MC and SC and it getting fixed. Everything inside of the housing while it was off was touched, either replaced or cleaned and greased and put back in with proper torque and best practices applied. I'll report back but any other ideas are always appreciated.
steel330i
« Reply #3 on: January 17, 2017, 06:30:44 PM »
UPDATE FIXED...
So perhaps installed a little off or something but the throwout bearing was a little "loose" and off of the spline, so re greased everything and back together and for the first time in 6 years, she's back on the road!!
E30 = Love
