Author Topic: FS: 1991 318i in SE PA, 134k miles well maintained  (Read 4507 times)
colin86325
« on: January 01, 2017, 02:46:26 PM »
Regretfully I need to sell my 318i to make room for a new vehicle. This has been an ongoing project over the past few years, with extensive preventative maintenance performed by myself, as listed below.  Car always starts up quickly, even in single-digit temperatures.
All numbers match on the body panels, no accidents or stories.  Clear coat peeling on the driver's fender.
Brilliantrot on Natur. Car is located in Glen Mills, PA.
Asking $4200
71 four three two thee 20 eight six  / colinmeaney at hotmail
For additional pics, see:
http://s287.photobucket.com/user/colin86325/library/318i
Maintenance since I've owned the car:
7/2016
replaced rear fuel lines
12/2015
4 new tires
11/2014
replaced belts for AC, PS, alternator
~120, 000 miles
replaced fuel filter and part of its supply hose
replaced fuel pump
upgraded low beam headlights (9007 bulb)
Replaced under-hood adhesive sound insulation pads
replaced hood cable
replaced cabin light
new water pump
new lower and upper intake manifold gaskets
new throttle body gasket
new fuel injectors
new fuel pressure regulator
new coolant temp sensor (2-pin for ECU-- 13 62 1 709 966)
new: all vacuum hoses
new: all fuel lines under the hood
new coolant hoses (two to the heater core and one from the expansion tank)
new plastic coolant junction pipe to engine block (11 53 1 709 052)
new heater core
new heater valve
cleaned idle control valve
new spark plugs
new air filter
new coolant
new throttle cable
new odometer gears and instrument cluster bulbs
new O2 sensor
flushed brake fluid
flushed power steering fluid
new driver's door lock cylinder
rebuilt rear driver's door lock actuator
rebuilt rear passenger door lock actuator
installed aftermarket antenna
new Pioneer CD/radio head unit installed with aux and USB inputs
new rear passenger axle
new rear driver's side window motor
flushed differential fluid
replaced muffler (stainless Walker Quiet Flow 3   PN#22380)
replaced turn signal switch (tab broke off for auto-cancel function)
flushed transmission fluid
new driveshaft center support bearing
new intake manifold boot (goes from air filter box to throttle body)
replaced Aux fan for condenser (was not turning on w AC switch)
replaced temp switch (located on on radiator) for aux fan (didn't fix aux fan problem)
replaced o-rings to coolant expansion tank on radiator (to fix slight leak)
replaced rear windshield (original was fine but many defrost lines did not defrost, hence replacement)
replaced front strut inserts and front strut mounts
replaced rear shocks and shock mounts
replaced front windshield
replaced windshield washer junction/check-valve
replaced aux fan diode (under fuse box)
replaced glove box latch
« Last Edit: January 01, 2017, 04:50:51 PM by colin86325 »
colin86325
Re: FS: 1991 318i in SE PA, 134k miles well maintained
« Reply #2 on: January 23, 2017, 06:12:58 PM »
Sorry to see you go - the car looks great. GLWS!
colin86325
« Reply #3 on: January 24, 2017, 10:34:55 AM »
Thanks Dave!
I still have my E30 318iS, and my E30 M3, so I'll still be around :)
colin86325
« Reply #4 on: February 21, 2017, 11:29:22 AM »
Sold.  Thanks for the interest!
