Author Topic: M42+44 turbo build  (Read 2768 times)
cwlo
M42+44 turbo build
« on: October 30, 2016, 02:20:36 PM »
So I am putting together a turbo motor, and have 2 early m42's and an m44 at my disposal.  I will be using CP pistons, and was planning on using the M44 block, late m42 front cover, and early m42 on the rest.  (head, crank, rods).
I am pretty sure this will all work together, but just want to run it by here in case I am wrong.
Thanks,
Chris
Darky
  • -Receive: 23
Re: M42+44 turbo build
« Reply #1 on: October 30, 2016, 03:40:05 PM »
Hi
That works
Bore is different though on the block.
Cheers
cwlo
« Reply #2 on: October 30, 2016, 04:03:50 PM »
CP pistons are a slight overbore, so no problem there.
Darky
  • -Receive: 23
« Reply #3 on: October 31, 2016, 04:44:22 PM »
It's safe to go 86 mm on the bore for forced induction build.
But you will need either a m44 head gasket or a metal head gasket
