Author Topic: Cam regrinding  (Read 2203 times)
sh123
Cam regrinding
« on: October 14, 2016, 03:49:48 PM »
Hi
Just looking for some info.
I cant get my head around how regrinding a cam works.
Surely if a cam is ground you will loose something somewhere.
Keep on hearing people saying theyve had cams reground to race spec at 300deg duration etc.
So if i have a standard m44 cam. 240deg 9.5/10mm lift ish?
Would it be possible to get a copy of metric mechanics rally cams which are 280deg and 11.5mm lift?  Where would the trade off be if any?
Sion
Darky
  • -Receive: 23
Re: Cam regrinding
« Reply #1 on: October 15, 2016, 06:06:09 PM »
Cam regrinding is a process where they first rough up the smooth cam surface then weld more material to the surface making the lobe bigger then grind the surface smooth again.
Advantages are is that it is relatively inexpensive.
Disadvantages are if the built up welded on lobe breaks off then that partular valve might 1. Be Stuck in up  2. Be stuck in down position.
Which can cause significant problems
Valves and pistons might argue!
