Author Topic: blower fan and power windows not working  (Read 3667 times)
Sytran916
« on: August 15, 2016, 02:14:57 PM »
i have a 91 318is, my blower fan and windows suddenly stopped working at the same time.  i checked the fuses, window switch breaker, and the ground wire under the dash by the brake pedal, everything looks fine.  my radio and obc work fine.  any suggestions?
Froos
Re: blower fan and power windows not working
« Reply #1 on: August 15, 2016, 03:48:30 PM »
Cracked wire harness? Is there power going to the window switches?
colin86325
« Reply #2 on: August 16, 2016, 10:45:01 AM »
Might be the Unloader relay, which is responsible for cutting power to those items when you start the car.  Also check the wiring at the starter.
Sytran916
« Reply #3 on: August 18, 2016, 03:06:58 AM »
It ended up being a bad remanufactured starter
