Author Topic: diy for Late Model Rear Bumper Trim removal?  (Read 4931 times)
jdt10768
« on: July 29, 2016, 01:52:57 PM »
Looking for the best way to remove rear bumper trim from a '91 318is (late model plastic bumpers) and would like to avoid breaking parts in the process
any experience with that?
Thanks!
Re: diy for Late Model Rear Bumper Trim removal?
« Reply #1 on: August 09, 2016, 08:10:52 PM »
I had a lot of trouble with that. The trim pieces are held in with spring clips molded into the trim itself. The trim pieces fit into grooves in the bumper face, so they should be carefully removed from the inside of the bumper shell. IIRC the bumper cover just has a few push-pin plastic rivets to hold it onto the core piece. Here's the diagram at RealOEM. Mine only had three rivets (part 2) and was missing all the shim washers (part 3).
The trim pieces are still fairly difficult to get at from the inside of the bumper shell. Maybe a modified plastic trim tool or even flat-bladed screwdriver could serve as a drift? I pushed a few of them too hard and made little cracks in the bumper around the insertion slots.
