Author Topic: Identifying an LSD diff ratio  (Read 2026 times)
Setanta
« on: July 13, 2016, 06:23:15 PM »
Hi there, I'm just trying to work out if this is a 4.11 LSD small case.
Is there anything I should be looking for other than leaky seals - and what oil is used in these?
Thanks
The tag reads 1041A4960S
Froos
Re: Identifying an LSD diff ratio
« Reply #1 on: July 14, 2016, 01:38:27 AM »
For oil you need castrol saf-xj 75w140
Darky
  • -Receive: 23
« Reply #2 on: July 14, 2016, 03:51:37 AM »
Hi
Yes it is a small case, back cover has 6 bolts. Medium has 8 bolts.
Count the number of teeth and divide the larger one by smaller one giving you the ratio.
Don't know what's up with the tag, it's not like any I have seen!
Cheers Rohan
