Author Topic: M42 conversion  (Read 3366 times)
CJackson
M42 conversion
« on: June 16, 2016, 12:58:13 AM »
Hi there,
Im planning to convert my e30 Coupe 318i (M40) to an m42 engine. I currently have most of the ancillaries required Inc M42 motor, E30 M42 Engine harness etc. However I only have an E36 M42 Coil pack.
Is it possible to run this engine with this loom on the E36 coil pack, and If so how would I go about connecting it to the loom as the E36 Coil pack has 5 pins whereas the E30 Coil pack has 5 separate leads?
Kind Regards,
Cooper
Darky
  • -Receive: 23
Re: M42 conversion
« Reply #1 on: June 16, 2016, 02:25:33 AM »
Short answer is yes.
Most people go coil on plug though.
The e30 m42 harness has 4 connectors and 4 Leeds
The e36 m42 coil pack has 1 connector and 4 Leeds
You just have to google m42 coil on plug conversion for the 2 different wiring harness, and do a bit of reverse engineering.
Which inlet manifold and Dme are u using?
Cheers Rohan
CJackson
Re: M42 conversion
« Reply #2 on: June 17, 2016, 01:44:19 AM »
Ahh okay will do, thanks!
I have the e30 ECU and the e36 Manifold, just bypassing and disregarding the existence of the DISA valve. Engine thankfully does not have EWS.
Why do you ask?
Darky
  • -Receive: 23
Re: M42 conversion
« Reply #3 on: June 22, 2016, 01:49:06 AM »
For that you will probably need either a e30 inlet manifold or e36 Ecuador.
They need to match because the air flow and then fuel need to match.
It will still work but just not quite perfectly.
