Author Topic: m44 318i overheating  (Read 2073 times)
CrusherCurtis
« on: May 19, 2016, 07:59:09 PM »
Picked up an e36 318i thats over heating. The lower radiator hose stays cold while the upper one gets hot. Thermostat?
dsm2002
Re: m44 318i overheating
« Reply #1 on: May 24, 2016, 10:21:11 PM »
Could be. I had a yamaha RZ250 which did that sometimes and I'd reach down squeeze the radiator hose. It was enough to start the coolant flow and the temp gauge would return to normal. Try this.
Overheating niggles really says "if the the cooling system hasn't been renovated (or is unknown) then you should consider doing it".
