Author Topic: Oil pressure and temp sensor location  (Read 6199 times)
Froos
« on: May 17, 2016, 05:26:45 PM »
A T or Y connector wont do, since the temp sensor wont be in the flued stream, according to vdo...any thought on where to put these sensors?
Darky
  • -Receive: 23
Re: Oil pressure and temp sensor location
« Reply #1 on: May 18, 2016, 12:25:44 AM »
What's the application turbo?
There's a spare Bung on the front of oil filter.
Froos
« Reply #2 on: May 19, 2016, 04:47:03 AM »
You mean rhis one? Any idea on its size of the threat?
Darky
  • -Receive: 23
« Reply #3 on: May 19, 2016, 05:34:49 PM »
Yes that's it just above and to the right of the arrow. Allen key required!
M10 thread from memory, but don't quote me.
Froos
« Reply #4 on: May 22, 2016, 03:18:21 PM »
Thanks man!
Delta
  • -Receive: 2
  • Freshly Registered!
« Reply #5 on: May 28, 2016, 11:56:05 AM »
Both the front hole (pictured above) and the port where the stock oil pressure switch is mounted are 12x1.5 thread. I ended up using the front port for my bro pressure sender and the rear port for my temp sender. Worked perfect for me!
Froos
« Reply #6 on: May 29, 2016, 11:52:54 AM »
Thanks i figured it was 12,5 to bad i have vdo meter so sender is expensive but ordered
