yeah it should just fail, cause its either 12 volts and it opens/closes, or it doesn't. its pretty easy to get too, you need to undo 2 hose clamps and pull off that plug. then your good to go. take it off, and get your battery and 2 wires and hook it up, see if it opens and closes, if it does give it a clean, if it doesn't... I'v got a spare you can pick up. and yes, plugs as in spark plugs, they could have fouled by sitting over the season.
