Author Topic: COP conversion wiring help  (Read 3107 times)
bflan2001
« on: November 25, 2015, 02:59:07 PM »
I'm trying to start a freshly swapped m42 and I think my coil wiring might be wrong. Is there an easy way to tell which plug goes to which cylinder? We tried shortest to longest and it doesn't want to start.
sh123
Re: COP conversion wiring help
« Reply #1 on: November 25, 2015, 03:29:43 PM »
This is for m44. But im pretty sure it will be the same. Scroll down a bit
http://bmwz3diys.weebly.com/coil-on-plug-conversion-bmw-z3-19-m44.html
bflan2001
« Reply #2 on: November 26, 2015, 10:25:47 AM »
Unfortunately the M42 is different. The geniuses at BMW decided to use identical wire colors for all four coil plugs on the M42.
sh123
« Reply #3 on: November 26, 2015, 12:21:11 PM »
Ah. Right. Fair enough... good luck.
bflan2001
« Reply #4 on: November 29, 2015, 03:16:02 AM »
For anyone who happens to stumble on this thread and has the same issue as me, here is the pinout so that you can do a continuity test on the wires to figure out which cylinder is which. Cylinders 1-4 are on pins 25, 52, 24, 51 respectively.
« Last Edit: November 29, 2015, 03:18:06 AM by bflan2001 »
