Author Topic: m42-idle problems  (Read 3115 times)
kobra
m42-idle problems
« on: November 19, 2015, 03:09:45 PM »
i just finished to swap an e36 m42 in my e30 and i started to have some problem. when is warm, the engine is stalling and have an erratic idle. i noticed that this happens commonly when i have light on, music on, blower on or any kind of electric consumer. if i close light for example, its ok for some moments and after that starts again until he dies. i just changed the battery with a new one bigger, new vacuum hose, new gasket for intake manifold, new sparkplugs, new oil and filter but the problem is not solved. before swap, the engine doesn't have this problem, or i didn't noticed. any ideas? see below video with my car
https://youtu.be/-Weyjf8kOrU
cristimm
Re: m42-idle problems
« Reply #1 on: November 20, 2015, 01:08:05 AM »
You should check the O2 sensor.
kobra
« Reply #2 on: November 20, 2015, 05:13:48 AM »
i will try this week-end to change o2 sensor.any other idea? the problems start after 10-15 minutes after i start the engine, when starts to warm up.when is cold its fine. also i noticed that when i start the engine, runs 3-4 turns before starting. any ideas?
