Author Topic: M42 removal question  (Read 3227 times)
giorgakis14
  • Freshly Registered!
« on: October 02, 2015, 02:10:45 PM »
Hey guys I'm in the process of removing my blown m42 for a m42 from a e36. Its my first engine swap and I'm familiar with all the parts I'm going to have to swap over. My main concern is if I should remove the enginr with the tranny or if I should just leave the trans in there. If that's the case does anyone have advice how to get to the upper bell housing bolts?
Thanks for the help guys.
keflaman
  • -Receive: 35
Re: M42 removal question
« Reply #1 on: October 03, 2015, 09:45:47 AM »
Welcome to the forum.
Depends on how you're situated. Do you have a lift or engine hoist? Are you going to do it on jack stands? You can pull the engine/tranny out as a unit from the top or bottom. I included a couple of threads below to give you an idea.
http://www.m42club.com/forum/index.php?topic=18614.msg127833#msg127833
http://www.m42club.com/forum/index.php?topic=14842.msg112380#msg112380
normboudreault
« Reply #2 on: October 03, 2015, 12:52:43 PM »
I had my car up on jackstands and removed it without the tranny.. It was a pretty tight fit to get it out...
The bolts on the bell housing are quite straightforward.. I got most from beneath the car and if I remember a couple from up top.. None were too difficult..
The "hard" part was getting the starter out..it requires some patience and a good selection of bad words..  ;)
If you can, remove the exhaust headers as this will make the whole thing easier...
Good luck..
giorgakis14
« Reply #3 on: October 03, 2015, 09:14:01 PM »
thanks for the help guys. its on jackstands whats hard about removing the starter? getting to the bolts from the trans side?
normboudreault
« Reply #4 on: October 04, 2015, 05:04:59 PM »
They were just hard to reach/get out.. They will come out but it was probabbly the most ardous part of removing the engine.. Dont sweat it..  ;)
giorgakis14
« Reply #5 on: November 03, 2015, 11:25:45 AM »
did you have anything supporting the transmission wile you where swapping the motor out? or is the tranny brace enough to keep it put?
