Author Topic: Bought used motor and found some issues  (Read 2126 times)
giorgakis14
« on: September 30, 2015, 11:53:35 PM »
hey guys,
My e30 has a bad motor so i picked one up for 200 bucks. took the valve cover off everything looked good also did a leakdown test and all the cylinders are within 4% my only concern is when i removed the tstat cover and the water pump i found that the cylinder walls have a lot of rust in them. when you look where the water pump goes. is this a serious issue or can i just clean it out with some vinegar and go on my way with the engine swap? thanks for the help
Darky
  • -Receive: 23
Re: Bought used motor and found some issues
« Reply #1 on: October 01, 2015, 03:59:23 AM »
Hi
I'd run it with a very dilute solution 5 % of vinegar for a couple of days, then check the rust. Once the rust is gone flush everything a lot and refil with grasshopper juice/water. U must get the vinegar out completely it will eat the engine if you don't. Can't stress that enough though.
Not going to cause major issues obviously a past owner didn't use coolant, grasshopper juice! But it will eventually cause problems with clogging things, radiator, thermostat etc.
Cheers Rohan
giorgakis14
« Reply #2 on: October 01, 2015, 09:41:01 AM »
ok sounds good thanks. another thing when i pull the old motor out should i pull it with the tranny or just the motor itself. i never did this on a e30 so i dont know whats easiest.
