m42 swapped to m20
Author Topic: m42 swapped to m20  (Read 4291 times)
doubled
m42 swapped to m20
« on: January 18, 2007, 03:31:21 PM »
Hello, i`m having some, i`ll tell you my story.
Bought 318iS - nice engine, but too low nM for me, so i decidet to buy from my friend m20b27 - build with 2.5 head - and other stuff.. at all - nice - powerful engine...
installed engine...
installed m20b25 engine wiring - and connected to C101 clip - at originall 318is.
in picture
Now i`m having problem, that - there`s no spark and fuel pump isn`t giving the fuel to injectors...
maybe some body, has did the swap like me, and knows some tips - what should i do? today i`ll checked that 318is that round wiring - has 11 wires, but bottom 325 - 16 wires... maybe i need to install some additional wires?
:confused:
thanks guys :)
some pic with my old 318iS engine @ track
kowalski
  • El\' Duder
m42 swapped to m20
« Reply #1 on: January 18, 2007, 04:17:37 PM »
did you swap to the 325 engine management and wirring harnesses? it doesn't sound like it... you need a 325 ecu and cables to be swapped in. nice e30 by the way.
Sale:
Fore Sale Thread
romkasponka
m42 swapped to m20
« Reply #2 on: January 19, 2007, 03:26:45 AM »
Hi neighbours ;)
I think you should replace ECU, if done it you should take multimeter and test all compenents wiring from ECU connector.
Why not M50? :)
E30 318is M42
E36 318is M44
doubled
m42 swapped to m20
« Reply #3 on: January 19, 2007, 07:54:24 AM »
swapped m20 engine with m20 engine wiring and m20 motronic ECU.
But "car" wiring - left old - 318iS wiring. fuse box and other things.
Why not m50.
Because i got this engine for cheap money, and that`s not stock engine, but guy build - engine is real powerful.
And i thouhg that swap will be easy,... now i`m thinking another thougts "about" easy swap... :(
romkasponka
m42 swapped to m20
« Reply #4 on: January 19, 2007, 03:27:30 PM »
you can try here http://www.bmwfan.puslapiai.lt/forumas/index.php?sid=c2bfce32c6691fbdb8c3a70c770e8c4d
there is few guys with big engine swap experience..
E30 318is M42
E36 318is M44
romkasponka
m42 swapped to m20
« Reply #5 on: January 20, 2007, 08:17:23 AM »
you should know that the M42 have direct ignition from ECU, and do not have relays at all for this function, it could be that M20 need few extra..
E30 318is M42
E36 318is M44
doubled
m42 swapped to m20
« Reply #6 on: January 20, 2007, 07:54:45 PM »
i have m20 engine wiring with these 3 relays...
today worked 7hours, but still no progress... i.m goin to kill myself :( :D
Gunni
m42 swapped to m20
« Reply #7 on: January 21, 2007, 08:00:16 AM »
are you getting 12v at the injectors?
and your getting 12v at the coil?
are you getting spark from the coil it self?
Whats the ECU # ?
Post up the wires in the C101 plug on both sides,
the numbers and colors,
Also what have you swapped with your friends 325i? And got no results
m42 swapped to m20
« Reply #8 on: January 21, 2007, 11:22:40 AM »
you could always go back to the m42 and boost...;)
hope you get it workin soon
