Author Topic: Need help  (Read 3813 times)
krisis54
Need help
« on: September 05, 2015, 11:53:51 AM »
Hi
What wire is this and where to connect it?
single connector, color:brown/white
monty23psk
  • -Receive: 17
Re: Need help
« Reply #1 on: September 05, 2015, 01:53:38 PM »
underneath the oil filter housing, its seen in the second pic, there is an oil pressure sensor. It connects to that.
krisis54
Re: Need help
« Reply #2 on: September 05, 2015, 02:04:53 PM »
Thanks a lot  :)
krisis54
Re: Need help
« Reply #3 on: September 05, 2015, 02:15:13 PM »
Another question there are two wires one goes to AFM and where goes the other one. does it goes to breather valve or vacuum control?
monty23psk
  • -Receive: 17
Re: Need help
« Reply #4 on: September 05, 2015, 05:14:13 PM »
if you mean that they are the same plugs, then only one goes to emisscion charcoal canister. The plug for the AFM is round and like a twist lock plug. You need to be more specific on the wires you mean. There are only 7 plugs like this for the engine:
1. oil pressure
2. temp sensor
3. temp gauge
4. crank sensor
5. cam sensor
6. emission charcoal canister
7. ICV
Going off memory but this should be it.
krisis54
Re: Need help
« Reply #5 on: September 05, 2015, 05:40:33 PM »
Thanks
I meant this one. I know that round one goes to AFM but the other one?
monty23psk
  • -Receive: 17
Re: Need help
« Reply #6 on: September 07, 2015, 10:26:31 PM »
goes to the emission charcoal canister between ATM and brake master cylinder but lower on the shock mount/wheel house, engine side.
krisis54
Re: Need help
« Reply #7 on: September 08, 2015, 10:32:33 AM »
Again. Thanks a lot  :)
