DISCUSSION
Swaps, Turbos, Buildups
M42 conrods help.
Topic: M42 conrods help. (Read 3762 times)
raivz
Freshly Registered!
M42 conrods help.
May 28, 2015, 06:21:29 PM »
Can someone help me figure out the conrod lenght needed for 8.5:1 compression ratio? original m42 rods are 140mm, and i dont want to change pistons because i've heard that orig. pistons are fine over 300hp.
Warsteiner
Hero Member
-Receive: 21
Re: M42 conrods help.
May 28, 2015, 10:38:53 PM »
raivz,
Wouldn't you rather change the head gasket and leave all the internals alone then?
from wazzu70:
.080” = 9.75:1
.098” = 9.34:1
.120” = 8.89:1
.140” = 8.52:1
Cheers,
~Ralph
raivz
Freshly Registered!
May 29, 2015, 04:40:48 PM »
I dont get it. Compressed headgasket should be .140(3.55600 mm)?
Warsteiner
Hero Member
-Receive: 21
May 30, 2015, 07:25:46 AM »
Yes. If you don't change you're bottom end, that is the way to change your compression.
Cheers,
~Ralph
raivz
Freshly Registered!
June 01, 2015, 09:49:21 AM »
I dont know, maybe stock conrods can't manage with extra power. So i thought maybe lower compression with new conrods. Can someone also giw me a hint what injectors should I choose. Car needs to be 300-350hp and reliable.
Thanks for the info
Raivo Villers
Darky
Hero Member
-Receive: 23
Reply #5 on:
June 01, 2015, 09:16:16 PM »
Hi
Standard connecting rods are fine for that purpose.
Just change your head gasket, so much easier.
Cheers
raivz
Freshly Registered!
Reply #6 on:
June 02, 2015, 10:45:35 AM »
how much stock rods can take? And which Engine managment system ms1 or ms2?
I thought maybe i'll swap m42 cyl.head to m44 cyl.head.
raivz
Freshly Registered!
Reply #7 on:
June 02, 2015, 01:01:55 PM »
I have two mazdaspeed 3 L3M7 turbos laying around. Both needs a rebuilt kit. And can someone tell me what injectors will fit in m42b18. I think i need 750cc to keep the duty cycle down and allow for some growth.
DISCUSSION
M42 conrods help.
