Author Topic: e36m42 coolant temperature sensor doesn't work on e30 body?  (Read 4137 times)
selespeed
« on: April 29, 2015, 09:27:43 PM »
hi;
i have original coolant temperature sensor of e36 replaced in my engine. but it doesn't work on my e30 cluster. why? this is a 2-pol sensor from VDO (12621747281).
the old sensor is broken while trying to remove to unplug the wire. this is the e30 sensor with 1-pol (12621710512). this worked on the e36 wire on my e30 cluster gauge.
i am puzzled? i think i should get a new e30=type sensor (1 pol) to work
Darky
  • -Receive: 23
Re: e36m42 coolant temperature sensor doesn't work on e30 body?
« Reply #1 on: April 30, 2015, 02:01:29 AM »
Hi
The temp sensor on the radiator?
selespeed
« Reply #2 on: April 30, 2015, 08:36:42 AM »
No. it's on the engine block. use the part # to check the diagram, you will see where it is.
shady62
« Reply #3 on: May 14, 2015, 04:33:43 PM »
I had all sorts of problems with my gauge/sensors when I first bought my e30 318is, turns out the previous owner had plugged temp sensor plug into the oil pressure sensor and vice versa. May not be any help to you mate but ya never know ;)
selespeed
« Reply #4 on: May 15, 2015, 04:13:16 AM »
coolant sensor: e30 wiring uses 1-pol sensor, while e36 wiring uses 2-pol sensor. anyway, this is NOT important for engine management because it is only used to sell the water temp. gauge for the driver.
bozzicek
« Reply #5 on: June 30, 2015, 11:08:58 AM »
I have exactly same problem, has anybody a solution?
Froos
« Reply #6 on: May 17, 2016, 05:13:01 PM »
Did you put teflon tape around the sensor? If remove it it causes ground issues
