So after finding bits of time here and there to play around with my new toy, here is some my progress, including some stuff im still deciding on how to tackle...
Got it high enough on stands and so far i've disconnected:
brake booster hose
2 x fuel lines
line to charcoal canister
2 x power steering pump hose (though I dont have a socket big enough for the larger one yet, anyone know the size?)
Then for electrical stuff I've d/c:
ground wire
loom cover
C101
removed the ECU
pulled the ECU connector through the firewall - damn that rubber grommet is a b@stard to get out!
Opened up the ECU and was glad to see it did actually have a performance Chip as the guy said it would - "Pro Performance" it says. whoever they're meant to be lol.
Been fighting a battle with the exhaust header lower bolts - they seriously arent going anywhere and im starting to round the nut. Ive done: degreaser+toothbrush to clean, WD40 soak and a few whacks with the hammer, then all leave overnight and repeat - but still no luck.
I'm thinking to just cut the damn exhaust near the cat as I'll be using the stainless one from my other E30 anyway... Unless anyones got magic tips for getting these bolts off??
So still got more to go like radiator/coolant hoses, driveshaft etc etc
