Author Topic: Lots of engine parts for sale m42 & m44  (Read 3694 times)
Nate.Vincent
« on: April 21, 2015, 01:18:04 PM »
Doing some serious spring cleaning and I have a lot of M42/M44 parts for sale.
-m44 cylinder head 120k cams out but I have all the parts.  Two slightly tweaked valves otherwise heads in great shape.
-m44 cylinder head 160K all complete.  Ready to bolt on looks like it was surfaced once before.  Probably could use a valve lap.
-m42 cylinder head 200k with just valves.  Two slightly tweaked valves. Has sat around for a while and will need rebuild/clean up.  Have separate set of cams if needed.
-m44 block
-m44 rods
-m44 pistons
-m42 block (a little rusty)
-m42 crank (a little surface rust)
-m42 rods
-m42 pistons
-m44 flywheel and clutch (98 318ti)
-2x m42 intake manifolds upper portion
-2x m44 intake manifolds both sections
-3x m42/m44 throttle bodies
-exhaust headers and down pipes from e30 and e36
-318ti radiator
-e36 oil pan
-e36 obdII harness uncut
-e36 obdII harness relays cut off
-e36 DME with stuff for ews
-3x valve covers
-e36 m44 auto transmission also z3
I have various other parts.  Please ask if you are looking for something m44 or m42 related.  If interested please email me at natevincent101 at gmail dot com as I don't frequent this site often.  Please make offer on parts.  Located in Connecticut.
pics:
fiftytakedowns
Re: Lots of engine parts for sale m42 & m44
« Reply #1 on: April 22, 2015, 01:14:34 PM »
Do you have a 91 318 engine, transmission, driveshaft  and harness?
amcink
« Reply #2 on: June 18, 2015, 12:49:49 AM »
Prices on the M44 heads?
