Author Topic: Rev Limit 4000  (Read 2923 times)
4638jay
Rev Limit 4000
« on: March 24, 2015, 06:45:43 AM »
93 318is m42 engine that rev limits at about 4100, showing code knock sensor #1 (1225).
Would this be causing the car to go into a limp mode, limiting it to ~4000 rpms?
Or is the knock code more likely a symptom than the cause?
Tgoode318
  • -Receive: 11
Re: Rev Limit 4000
« Reply #1 on: March 24, 2015, 08:00:35 AM »
No it is not cause enough alone to make the car go into limp mode.
-'94/05 M42 Convertible
-2001 330CI M Package
-2016 M4 Competition
4638jay
Re: Rev Limit 4000
« Reply #2 on: March 24, 2015, 05:51:05 PM »
If a previous owner swapped the instrument cluster with one from a 325, would it cause the RPMs to be off?
EDIT: Revs go up to 6500 on the instrument cluster printout, so I don't think this was related.
« Last Edit: March 24, 2015, 09:50:23 PM by 4638jay »
4638jay
Re: Rev Limit 4000
« Reply #3 on: March 26, 2015, 05:29:50 AM »
I got a better look at the tac last night, the rev limit occurs at 4500 not 4000, does this point to a problem with the differential speed sensor and instrument cluster?
Tgoode318
  • -Receive: 11
Re: Rev Limit 4000
« Reply #4 on: March 27, 2015, 07:47:38 AM »
Your best bet is to get a copy of the bently manual for you cars year and get a multimeter to test all of your sensors; the one your mentioned is a possibility but other possibility's include but are not limited to a crank sensor a cam sensor or even worn cam lobes *god forbid*. Is this problem in neutral or when driving? Or both?
colin86325
Re: Rev Limit 4000
« Reply #5 on: March 27, 2015, 01:16:50 PM »
Yes!
I had that exact problem with my M3.
