Author Topic: My m42 SC build  (Read 3448 times)
AdOz
My m42 SC build
« on: January 30, 2015, 11:45:57 AM »
I'm currently building an e10 and I've got hold of an e30 m42 engine and box
My plans are
Eaton m62 charger (already got)
Plenum manifold (currently building this)
Bigger injectors
Standalone management
M20 clutch and SMF
Basically I came here to share my progress and get some advice from the experts!
Currently I'm building the manifold and it should be done on the next week but my first questions are...
What are the best injectors to go for il be aiming for high 200s-300hp
Whats the preferred standalone management on here?
Which m20 clutch and flywheel do I need? Part numbers?
SkidMark
  • ex pro bmw wrench.. 15 yrs bavarian auto haus
  • OO==[I]==OO
Re: My m42 SC build
« Reply #1 on: February 18, 2015, 08:00:28 PM »
Hi there!
Sorry I didn't see your post and questions, I have been super busy.
Well as far as your quest for 300hp with a m42 engine, I think you are dreaming. I am not saying it is not possible, but seems a stretch.
You didn't mention what your budget is and your internal engine plan is. 300hp will require some extensive mods, rods, pistons, and cams for starters. Cosmetic head gasket, and some headwork too. Do you plan on changing the s/c pulley on the s/c? My eaton g62 from a c230 only makes 6psi to 7psi max with the Mercedes stock electro mag pulley. It dosent even start making boost until about 3000rpm. My setup is a bone stock e36m42 with the exception of 36# injectors, coil on plug conversion, m20 flywheel, stage 2 clutch, custom intake, and obviously an eaton g62 supercharger. I use a bosch bypass valve from an audi for boost return. It works off vacuum and is basically "open" returning boost into the intake until manifold pressure becomes positive, not vac.  I use a e30 m42 ecm, with a custom chip from Jake at Classic Daily. It is a detuned turbo chip that he made from his tried and true turbo tune, just scaled back a bit as he runs much more boost, 10 to 12psi. I think my car is probably only making 200hp, which is pretty good for a junkyard m42 with unknown miles. It runs great and pulls very hard. It is in a 1979 e21 320i which is a light car though.
Well, back to you, also in my opinion you don't need an intercooler but that's just me. The eaton g62 is very efficient and does not create much heat. Space also becomes an issue when it comes to routing all the charge pipes and such. As for the flywheel, any e30 m20 flywheel will work but you will need to make a spacer to go in between the crank and flywheel. I used an old auto trans flexplate from the donor car  I got my engine from as it was an automatic trans car. I used the e21 throwout bearing as well as the slave cylinder. If there is anything I can help you with let me know..... Skid
Here are some photos of the belt routing, best I could get. I used Subaru timing belt bearings. They are stout and worked perfectly. My setup uses the stock e36 tensioner. Also you can see the bosch bypass valve in on of the photos...
1970 BMW 2002, 1988 BMW 325ix, 1979 BMW 320i m42 powered race car, 1969 BMW r75 cafe bike, Greasy fingers, Empty bank acct, Pissed off wife, Unhappy dog, Filthy garage.
