Author Topic: M42 ENGINE Parts Cams, Injectors, Starter, etc  (Read 5027 times)
e3091318is
« on: January 06, 2015, 08:26:57 AM »
Cam Shafts (intake/exhaust) Hot tanked, cleaned, and air compress dried.  No rust or major wear. $100 shipped.
WPS Starter - $40 (tested and does work)
Spark plug wire tray holder - $15
Set of timing chain gears (upper cam shaft gears) - $35
Rear main seal housing - $15
Crankshaft Main bearing caps (5) - $25
Radiator Coolant Temp Sensor - $20
Cam Shaft Trays (hot tanked, cleaned) comes with holders on top for cams - $35
Fuel Injectors (should probably be serviced while out but worked as intended) - $40
« Last Edit: April 30, 2015, 02:28:28 AM by e3091318is »
2000 Mercedes S500 (Sold)
2001 BMW 325CiC (Sold)
2003 Honda Accord Coupe EX-L V6 (Sold)
2001 Audi A6 2.7T (Sold)
1984 318i Coupe (Sold)
1991 318is Coupe (Current Project)
e3091318is
Re: M42 ENGINE Parts Cams, Injectors, Starter, etc
« Reply #1 on: March 06, 2015, 05:35:50 AM »
bump.
benz-tech
« Reply #2 on: April 27, 2015, 06:16:56 PM »
What year car are these from?
e3091318is
« Reply #3 on: April 30, 2015, 02:28:42 AM »
1991
JohnathanOttman
« Reply #4 on: June 14, 2015, 02:43:54 AM »
would you have an engine harness ?
e3091318is
« Reply #5 on: July 22, 2015, 02:17:34 AM »
No sorry
topik
« Reply #6 on: September 10, 2015, 08:49:26 AM »
I'm interested in the camshafts w/ caps and trays if they are still available. Are you willing to ship?
