Author Topic: fun with a stuck water pump  (Read 2672 times)
colin86325
« on: December 01, 2014, 09:22:27 AM »
So it finally happened to me: after reading countless stories of M42 water pumps being stuck, mine finally did the same.
I tried to slowly and evenly use the jack screws on the pump base to separate the pump from the engine, but of course they both broke the pump base. Then I resorted to smashing the pump left and right with a 5lb hand sledge with PB Blaster applied to the pump.  I'd alternate with round of prying with a 3ft prybar, which I could feel was flexing under the strain i was applying.  Then some heat with a mapp gas torch.  Repeat cycle...
What finally worked was a 4ft crowbar, applied from the driver's side.  I pried against the flange where the pulley mounts, and the pump finally gave way after I applied considerable pressure.  The coolant that came out was pretty disgusting, and the resultant corrosion was doubtless the reason the pump was so stuck.
Anyway, I hope this helps somebody.  I really hope I don't have to do this job again soon.  I applied some anti-seize paste to the pump to hopefully make the job easier in the future.
« Last Edit: December 01, 2014, 09:24:23 AM by colin86325 »
deansweet
  • -Receive: 12
Re: fun with a stuck water pump
« Reply #1 on: December 01, 2014, 11:15:04 AM »
That sounds like you you had a good time...
Amazing how such a small thing can cause so much anxiety.
colin86325
« Reply #2 on: December 01, 2014, 11:49:33 AM »
A wave of joy came over me when the SOB finally broke free.
I was expecting the job to take 40 minutes, not 3 hours though!
