Author Topic: 1991 BMW E30 318IS S50  (Read 3253 times)
blackhawkimpact
« on: October 16, 2014, 08:24:17 PM »
Up for sale is my 1991 BMW 318is. I bought the car pretty beat up with an overheated engine. Paint was gone. I put a lot of work on this car. All the work was done by me except for the welding on the exhaust. I did an engine swap a year later. Engine is from a 95 BMW M3. Guy I bought it from said it has 89k when pulled. I've spent so much money on this car that I hate to see it go. Reason I'm selling it is that I got another job and I'm making a little less than I was. I've spent a little over a grand alone just trying to get it BAR legal alone. I've been having trouble with the ref and the cats trying to pass smog. I've bough two different set of cats and both set were supposedly the wrong cats. Long story short, I ran out of money to buy the right cats.
NOTE: Car will not come with the Centra wheels. One wheel is bent. You will get the car with 14" basketweaves.
Year: 1991
Make: BMW
Model: 318is
Mileage: 168k on the chassis
Transmission: Getrag 5-Speed
Color: Diamantschwarz-Metallic
Engine:
95 BMW M3 (89k)
Stock brake booster
413 Red label DME
95 BMW M3 harness
All gaskets replaced
All fluids changed
Belts replaced
New mounts
New waterpump
New thermostat
TRM chip
Pink injectors
Cone filter with stock 3.0 MAF ( I have a custom made stock m20 airbox with a 3.5 MAF if you want that instead)
eBay headers
91 octane gas all the time
Rotella T6 Full Synthetic 5W-40
140W alternator
New sensors
Spal pusher fan
New battery (1yr warranty)
Transmission:
BMW Z4 shifter (short shifter)
Getrag 240 5 speed transmission
Stage 2 Clutch
Single Mass lightweight Flywheel
Interior:
Euro clock
Maplight rear view mirror
All black interior
"Premium" speakers/tweeters
Sport seats
Rear seats with armrest
Custom cupholders From SFGadgetGuy
Custom e34 visors with dome lights
E34 tool kit with all tools including safety triangle
Electrical:
e36 radio
E36 Z3 antenna base with S2K antenna
E36 window/sunroof switches
Exterior:
5% tint all around
All red taillights
New paint with 4yr warranty left
New OEM lip with lip splitter
OEM fog lights
Sealed beams
Driveline/Suspension:
Chassis is straight, strong, with no rust. 169k on the chassis
3.73 LSD
E30 M3 steering rack
Vibrant muffler
New tie rods
E36 325 driveshaft
New CSB
New Flex disc
I have all the receipts that I've done to the car myself.
Cons:
1) Dash has a crack in the middle
2)Heater core delete/ AC delete. So no AC or heat. Also Odometer works on and off. I replaced the gears a while back but IDK if I installed them incorrectly.
3) Needs smog in order to get the tags. Registration is paid for thru 2015. Car passes smog with flying colors. The only thing that's keeping it from getting BAR'd is the cats. As of right now the cats that are installed are supposedly the wrong cats so that's why the ref fail me. But I have the papers showing that that's the only thing it will need is to get the right cats.
4) Car holds a Salvage/Rebuild title. Chassis is straight and their is nothing wrong with the car.
Price:
$10,000 if I get the cats and pass smog. $9,000 if you take it as is. The car is clean body wise. Don't let the salvage title scare you away. No test drives without cash in hand.
Currently I researching on the right cats I need. I will revise the post if I fix the problem. Car is located in Pomona, CA
Thanks for viewing
Click here for pics:
http://www.r3vlimited.com/board/showthread.php?t=334606
2002 BMW 325i
1991 BMW 318is S50
1983 Porsche 944
