Author Topic: uk m42 tuning  (Read 2086 times)
mtechstevo
  • Freshly Registered!
uk m42 tuning
« on: October 14, 2014, 07:36:45 AM »
Hi all just signed up here as I have an e36 318is with said m42 engine and am looking for tuning tips. I want to go with an n/a setup as not many over here bother. I have found some uk injectors can be used off a vectors v6 in place of the mustang ones used over the the pond. I was wondering g what else other people do?
Any ideas gratefully received
Steve
Tgoode318
  • -Receive: 11
Re: uk m42 tuning
« Reply #1 on: October 15, 2014, 12:25:28 PM »
Hey mtechstevo welcome to the club. The M42 from a n/a standpoint is very well tuned from the factory and you will be hard pressed to get much more power out of it with out doing some major modifications (i.e Cams/Stroker/ ITBs/ etc..) If you are looking for a small bump in power with out spending an arm and a leg though , I would recommend A good
Chip tune
http://www.turnermotorsport.com/p-4052-e36-318iis-1992-1995-turner-motorsport-conforti-performance-chip.aspx
Underdrive pulleys
http://store.vacmotorsports.com/vac---underdrive-power-pulley-set---m42-e36-only-p1666.aspx
Fan mod delete kit
http://understeer.com/onlinestore-engine.shtml
And a light weight fly wheel.
If you do all the above it should be much more responsive and fun to drive as well as a small increase in BHP. Some other options after you have done all that would be to look at intake system's and exhaust systems all though the gains here are very minimal if any.
Good luck!
-TG
« Last Edit: October 15, 2014, 12:29:35 PM by Tgoode318 »
-'94/05 M42 Convertible
-2001 330CI M Package
-2016 M4 Competition
