Author Topic: Fresh rebuild REALLY noisy  (Read 3517 times)
Chodedub
« on: August 22, 2014, 05:14:10 PM »
So i bought a 91 318i rebuilt the motor this winter and am just getting to run it now. The head and rotating assembly were assembled by the machine shop that did the work. Upon start up i expected a loud motor as per oil having to get around the motor but it didn't quiet down after about 5 mins of run time. I'm nervous about running it any longer then i already have, i pulled the valve cover off and checked everything seems to be lubricating properly and no wearing that i can see. HELP!!!
colin86325
Re: Fresh rebuild REALLY noisy
« Reply #1 on: August 22, 2014, 05:54:37 PM »
Remember that the hydraulic lifters will probably need to bleed out the trapped air after all that time.  There might also be another problem, but I'm just saying that this could be the root of your concern.
Have fun!
Chodedub
« Reply #2 on: August 22, 2014, 07:01:47 PM »
Roughly how long should this bleeding process take?
SkidMark
  • ex pro bmw wrench.. 15 yrs bavarian auto haus
  • OO==[I]==OO
« Reply #3 on: August 23, 2014, 08:09:58 PM »
If you replaced the timing chain tensioner the engine will be very noisy until the tensioner releases. Yor have to rev the engine quite high to build up enough oil pressure to release the tensioner. 4000 rpms if im not mistaken... It could be your problem. You could also remove the tensioner and see if it has indeed released... Skid
1970 BMW 2002, 1988 BMW 325ix, 1979 BMW 320i m42 powered race car, 1969 BMW r75 cafe bike, Greasy fingers, Empty bank acct, Pissed off wife, Unhappy dog, Filthy garage.
Chodedub
« Reply #4 on: August 24, 2014, 05:34:21 AM »
ok great thanks ill check it
colin86325
« Reply #5 on: August 25, 2014, 07:50:45 AM »
Here's a procedure for bleeding that should still be applicable:
https://www.youtube.com/watch?v=XwTfFesA-yo
Nick_318is
  • -Receive: 11
« Reply #6 on: August 25, 2014, 08:40:09 AM »
If the timing chain tensioner is the problem I'd suggest releasing it before you put it back in, will be a little harder to thread in but you should be able to do it.
Chodedub
« Reply #7 on: August 28, 2014, 03:58:32 PM »
So i found the problem and it was a goof on my part, i put the lifter trays in on the wrong sides... Needless to say im in need of a whole new top end now....thanks for the help tho guy muchly appreciated and if anyone has any m42 parts kicking around that wanna send them my way that would be muchly appreciated as well lol cheers
