Hello guys,
I decided to create a variable length ITB on my M42B18 (E36 318IS coupe EU version - I live in Hungary) with a little bit modifications. I ordered the intake manifold from RHD and I designed the rest of the parts. As you wrote I also put non-hardening silicone sealant and applied it around the edge of the butterfly valves. I wanted to keep my ICV so I connected it to the vacuum block. I also kept the PCV valve, that is connected to the vacuum block with an additional vacuum block adapter. DISA and carbon EVAC cansiter valves are not connected into the system right now (electric cables and vacuum lines are also disconnected).
My questions:
1. I wanted to synchronize the ITB-s with a synchrometer, but without airbox and air flow sensor the car idles rough, so it is not possible. It idles between 1200 and 2000rpm. Did you synchronize the throttle bodies or just put it together and it runs fine without synchronization?
2. The car starts usually only once without airbox and air flow meter. For second try it cranks but I can not start (after waiting a day, then start again for the first time). Injectors and plugs are ok. Did you have similar symptoms?
Thank you for your help!
