Hey guys,
New member here with just a couple questions about the M42. So I'm looking to pick up a track car, and I found a pretty sweet 1991 318is with a few mods here and there. One big issue is that it has some rod knock, and the bearings need to be replaced. I understand parts wise this is fairly cheap but it is a pretty heavy DIY from what I understand. Does anyone have any links to a great rod bearing replacement DIY? Pretty handy with cars, just usually need a DIY to help kick start it, especially when I'm only used to working on N54 engines.
Also the car has 270k miles on it, not sure if this is engine & chassis miles or just engine. I wouldnt really expect it to last much much longer than that but then again M42's arent my cup of tea.
Here is some details of whats been done on the car and what needs to be fixed:
·New Radiator & thermostat
·All new front timing case gaskets (top & bottom)
·New timing chain tensioner (new style m44)
·New valve cover gasket
·NGK spark plugs
·New O2 sensor
·New transmission fluid
·New intake boot
·New intake manifold gasket
·New throttle cable
·All new oil pan gaskets (upper & lower)
·New fuse box cover
·New fuel pump (in box) & pump relay
·New Bosch Idle Air Control Valve
Upgrades:
·M-Tech Rear Spoiler
·Limited Slip Differential from 87 325is
·Ebach Lowering Springs
Tokico Blue Struts
·E30 M3 Front & Rear Swaybars
·Supersprint Magnum Exhaust (headers back)
·Custom Intake
·New BMW emblems (front & rear)
·Alpine Speakers all around
Cons:
·Engine has a rod knock (set of OEM bearings is $35)
·Driver seat is a little torn due to previous owner
·Dash is cracked (common in e30, it's a 1991)
·Odometer doesn't work (gear set is $65)
Thoughts anyone? Thanks for the help!!
