DISCUSSION
Engine + Driveline
E30/E36 hybrid diff - STW replica.
Topic: E30/E36 hybrid diff - STW replica. (Read 2172 times)
E36-italia
-Receive: 6
June 23, 2014, 02:12:39 PM »
Hi Guys,
Does somebody know if it is possible to swap the rear cover from an smallcase E36 diff on to a E30 small case diff? (and mount it on a E36 subframe-ish)
The 1995 STW cars had a diff which looks like a E30 small case.. but with two 'ears' on the rear cover.. like the E36 ones...
IlovM42
Re: E30/E36 hybrid diff - STW replica.
June 25, 2014, 11:17:28 AM »
you can swap the rear cover from to identical diff, but be carefull, on E30 there is type 168 (small) and type 188 (big) on E36 IIRC there is 3 type 168, 188 and bigger but the biggest may be on M3
DISCUSSION
Engine + Driveline
