Author Topic: No power steering.. Help  (Read 4254 times)
aintnothang
« on: April 19, 2014, 06:22:24 PM »
I have no power steering in my 91. Everything is hooked up, belt, reservoir is full... Is there a way to check to see if the pump itself is bad?
JM35
  • M42 Track Car?
    • OEM & Performance BMW Parts Online
Re: No power steering.. Help
« Reply #1 on: July 22, 2014, 08:13:25 PM »
If your fluid levels in the pump are good and you here it making a whining noise that is usually a good indication. You may also feel hard spots in the steering once in a while. A leak in the pump could also indicate a problem. However, leaks in the steering are usually the fault of the high pressure hose.
2008 535i Sport Pkg
2007 335i Sport
2007 Mazda Rx-8
E30 Parts
