So I went ahead and replaced my upper oil pan and will explain how I did it for future users' reference. Faced with the choice between removing the suspension components or lifting the engine to get out the upper oil pan, I chose the lift option. Here's what I did:
1. Put the the front end up on stands
2. Removed the fan shroud and fan
3. Removed the hood
4. Used a small lift to slowly raise the engine. I had read from other e30 models (m20 engine, for example) that you could keep the nuts of the engine mounts attached at the very end of their threads and still lift the engine just enough to pull the pan out past the suspension. From my experience, that doesn't work with the m42, and I ended up tearing my motor mounts. Sucks, but they were the originals so could use replacing anyhow. Either way, if you want to keep your motor mounts make certain you completely remove the nuts before lifting.
5. I would say you need at least six inches of lift to slide the pan out.
6. This has been covered in other posts, but make certain you count all your pan bolts since those 6 near the sump (on the inside of the pan) completely worked lose and were sitting in the bottom of my lower pan.
7. Cleaned both pans, replaced gaskets (using RTV black) and carefully (with help) slid the pan back into place.
Point is, you CAN replace the upper pan on an M42 by slowly lifting the engine a minimal amount.
Cheers!
