Author Topic: how do i reset my factory radio?  (Read 2925 times)
rabidroco
« on: January 08, 2007, 10:38:44 AM »
I disconnected the battery and now it asks for a code.
thanks
dhirsch
« Reply #1 on: January 08, 2007, 11:15:38 AM »
The code was originally given to owners with the owners manual packet.  If you have that it should be in there.  If you do not have it you might be able to get it from a dealership, but I'm not sure.
RED IS 91
« Reply #2 on: January 08, 2007, 01:08:00 PM »
You will have to remove the radio to get the seriel number off of it then call the dealer .Tell them the number and they should give you the code .Then you will have to do some programing and if you hold your tongue just right the radio will accept the code . If not then you will have to unhook the battery wait 10 or 15 minutes then try again.
Wouldn't want anyone to steal your radio which is worth about $20 .
I know there are posts out there that have to do with this .I'll search for you and let you know.
Read this , it will help you with the procedure
http://www.unofficialbmw.com/phpBB/viewtopic.php?t=25687&highlight=radio+codes
 Your car is telling you it wants a new clarion head unit ..........
When I needed the code for mine I pulled it out and got the serial number and called the dealer .NO problems , gave me the code right over the phone.  good luck
« Last Edit: January 08, 2007, 01:19:51 PM by RED IS 91 »
jpod999
« Reply #3 on: January 08, 2007, 04:47:12 PM »
When I bought my car, the lady had a card in the BMW leather folder thing that had the code in it.  Might want to look through your stuff and see if you have it.
rabidroco
« Reply #4 on: January 09, 2007, 05:48:19 PM »
thanks! ill try that.
magnum2066
« Reply #5 on: January 09, 2007, 07:21:34 PM »
This might sound lame but there is a code printed on the plastic inside my glovebox just to the right of the one sticker dealybob.
I have a 91' 318is.
