Author Topic: E30 Airbag wheel diagram?  (Read 4414 times)
AlpineE30ic
« on: February 03, 2014, 10:57:48 AM »
My e30 convertible came with an M-Tech I wheel which id like to remove and put the stock airbag wheel back in. I tried to do this however the airbag wheel seemed to drag with a lot of friction.. with that said, I'm looking to see if anyone has or can point me towards an assembly diagram to make sure I have all the right parts in order
thank you!
Re: E30 Airbag wheel diagram?
« Reply #1 on: February 03, 2014, 12:31:27 PM »
Do you have the correct spacers? There should be a small ring spacer that fits under the airbag wheel. It's part #4 in this diagram.
The wheel itself is not represented in that diagram, but it's fastened by nut #2 & wave washer #3 and sits on top of spacer #4 (BMW calls it a "14mm ring").
Not sure if you know this, but the airbag control stalks are not the same as the non-airbag ones. The airbag wheel is deeper than the non-AB wheel, so the matching stalks reach further toward the driver.
« Last Edit: February 03, 2014, 12:33:03 PM by DesktopDave »
AlpineE30ic
« Reply #2 on: February 04, 2014, 07:27:24 AM »
this is a great start, thanks very much. I'm pretty sure that # ring is not in there right now so that would explain it. Is this the same ring thats required for the Mtech wheels as well? I remember buying one for the mtech on a another project car which needed it in order to eliminate the wobbling of the wheel
thanks again
« Reply #3 on: February 04, 2014, 03:11:27 PM »
I believe they are the same. I had to use two in mine - one under the wheel and one above it.
