Hi everyone. I'm hoping someone might give me some insight on this problem I'm having:
I seem to have a coolant leak where the plastic return pipe comes out of the block. Coolant pools in the small concave area right under the pipe. I have replaced the O ring, but the pipe seems to be separating from the block and weeping coolant, as if there is a lot of pressure pushing it out.
Coolant temp never gets to the exact middle of the gauge; it always sits one click below, or just a bit above that. I'm running 50-50 mix of dealer blue coolant.
I noticed yesterday, after running errands, that the coolant hose going into the radiator was hot (normal), but that the throttle body heater plates (vertical and horizontal) were cool, and the metal "u-turn" connector that connects the two combo coolant/pcv (?) hoses under the intake was also cool.
It seems to me that the throttle plates and the "mess under the intake" metal pipes should be full of hot coolant, right?
Since they are cool, and the radiator hose is its normal hot temperature might there be a blockage? Could this cause pressure to build up in the plastic pipe, making it separate from the block (we're only talking one millimeter, but noticeable that it isn't perfectly flush), and therefore leak?
It'll drop about three inches in the coolant overflow tank about every two weeks, and there is always coolant pooled in the area under the pipe.
Best regards,
Tim
