Author Topic: MAF Wiring Questions  (Read 2666 times)
jajou318
« on: January 06, 2007, 07:01:01 PM »
I know(now thanks to Gunni's post) that I need to get to these wires. Is it just tapping them from the ecu? And how do i know which wire it is? Is it as easy as counting the number 41 wire and the #77 wire?
41 AFM Input (5v) GY/YL
77 Air temp input GY/VI
Also, I have no clue as to where to look for the TPS signal  :???:
edit: dude8383 showed me where it's at... Guess i have a diff q now.. is there only one wire behind that grommet and covering?
As for the oxygen sensor for wiring the guage I could just tap that directly from the oxygen sensor so I think I'm ok on that.
edit: i believe there are two wires, anyone know which one to tap?
somewhat of a teaser...
scottiesharpe
    • http://bmwturboperformance.com
« Reply #1 on: January 06, 2007, 08:52:54 PM »
I disconnect the battery and the ECU and then I use a continuity tester to figure out which wire goes where.
I had to run an 12v wire from the ECU out to my MAF. Otherwise I was able to use all of the stock wiring.
Scottie Sharpe
San Jose CA
www.bmwturboperformance.com
67 1600
68 2002 Dual Mikunis
73 Hardy & Beck tii
88 M5, Dinan Stage 4, M88, MAF
91 318iC, MAF
Do you BMW Wiki Wiki ?
jajou318
« Reply #2 on: January 07, 2007, 05:31:39 PM »
Ok, I've found the wire for the a/f ratio guage.
70 O2 Input BK
I honestly think that may be it.
