Author Topic: Rear Sway bar question.  (Read 3107 times)
« on: January 06, 2007, 12:19:04 PM »
No.DescriptionSupplement           Qty Part Number   Price
01 STABILIZER BAR REARD=14MM 1    33551091621 $121.64
FOR VEHICLES WITH
M SPORTS SUSPENSION
01 STABILIZER BAR REARD=16MM 1    33551090317 $129.46
realoem shows a 14 mm rear as standard on a 1994 E36 318ti Compact and a 16 mm for the M Sports.
Does anyone know if the E36 16 mm bar for the Compact M model will fit?
The rear suspensions look the same and the differential, cross member, and trailing arms are like an E30 instead of the regular E36
        __________________
AL GReeNeRy
« Reply #1 on: January 07, 2007, 10:23:58 AM »
good question.. if they fit, i think i might have to try out a new setup.. 21mm front cabby sway with 16mm rear e36, e30 m3 end links and all new bushings...  thatll be a hell of a lot cheaper than even the suspension techniques kit...
1991 318is : brilliantrot
